  #1
Old August 3rd, 2004, 07:43 AM
geezus geezus is offline
Default 90 h.p. Mercury oil sensor...
Been through this before... on my 90 hp. The low oil sensor alarm going off. The first time was dry rotted oil lines when i first bought the boat. Second time was when I had to replace the whole tank or the sensor itself. Because it went bad. If I recall it was the whole tank. Am I correct ? ANYWAY.. things have been going great since I replaced the sensor. But, was putting my boat in the water last night and heard a faint squeel of that alarm about to go off by the throttle handle. So I checked the oil, and it was fine.And then the alarm went off 100%.. What are the other possible causes of this. I had the boat on the water just recently and no problems. What could go wrong in between that period and now.?? grrrrrrrrrrr :o !!!!!!!!serial number OB302405
  #2
Old August 3rd, 2004, 07:58 AM
Default Re: 90 h.p. Mercury oil sensor...
I'll do some reading here, before someone has to type a bunch of stuff.. I just thought it was strange that I started out through the marina *no wake zone* and the alarm was wanting to go off, and then it started squeeling more often, and then 100%. Almost like there was a short in a wire somewhere. Maybe I'll just take the tank off, and mix my own oil !
  #3
Old August 3rd, 2004, 08:19 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
What sort of alarm? Beep, beep, beep. Or beeeeeeeeeeeep.One is low oil, the other is overheat. You could eliminate the tank sensor from the fault finding (or prove it's the cause) by isolating it. ie, disconnect one of the sensor wires and check for the alarm.Chris............
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #4
Old August 3rd, 2004, 09:05 AM
beeeeeeeeeeeeeeeeeeeeeeeeeeeeeep !~~~~~~~~~starts when you turn the ignition !!!! and doesn't stop !!!!!!
  #5
Old August 3rd, 2004, 09:52 AM
achris's Avatar
Could be a shorted wire somewhere...Or....The alarm module has Gone To God....But definitely not the oil tank sensor!Chris............
__________________
  #6
Old August 3rd, 2004, 10:06 AM
that's what i was thinking. Because it slowly started getting worse... when I first headed out ..it was barely ,chirpin !!!!! then "slowly" got worse ! Will check the connections out in the throttle handle... correct ?
  #7
Old August 3rd, 2004, 04:44 PM
achris's Avatar
If you disconnect the tan/blue wire from connector 'o' and the buzzer stops the module or the temp sensor is at fault. If it still beeps then you're looking for a short somewhere.Chris...........
__________________
  #8
Old August 3rd, 2004, 06:47 PM
saumon saumon is offline
Hi acris, i see that you scan some nice diagramms and place them on myfishingpictures.com, but i can't find them cause i don't know your member name on the other board.
  #9
Old August 3rd, 2004, 06:52 PM
oh! i found it, it's mahi01.
  #10
Old August 3rd, 2004, 07:29 PM
achris's Avatar
Saumon,I usually take them off after the people on this site have finished with them. Usually about 2 weeks.Chris...............(Mahi01)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 115 temperture sensor bradon1 Force & Chrysler Outboards 2 June 22nd, 2006 05:12 AM
Mercury Thunder bolt ignition sensor problem Rculmone Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 June 30th, 2005 10:11 PM
sensor shep70057 Yamaha & Suzuki Outboards 1 February 13th, 2005 02:14 PM
Temperature Sensor, 1990 60hp Mercury olyerickson Mercury & Mariner Outboards 7 October 18th, 2004 10:15 AM
1998 Mercury Optimax temperature sensor: at what temp does it come on? milo98 Mercury & Mariner Outboards 8 November 10th, 2002 11:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
