Re: Mercury Temp guage sender?
Yep, parts 26 &27. It's a brass sending unit with a little aluminum holding plate. I finally got one off a trade-in motor at the shop in Rockwood. I was surprised I couldn't just buy one of these at one of the Marina's. The sender is treaded into the mounting plate, should it be adjusted to contact the base of the socket?, Or to not touch anything? Seems to work, my V-6 is reading 130 to 135 most of the time. A little hotter after coming down from WOT, and much lower at low rpms starting out. BD
