  #1
Old July 27th, 2004, 05:28 PM
walke933 walke933 is offline
Default No Tell-tale stream at high throttle - Mariner 15HP
I have a Mariner 15HP, 2 Stroke (not sure of the year) that doesn't give off a tell-tale stream when running at high throttle. At lower throttles, there is a good stream. At high throttle one of two things happens:1. Stream slowly dies away and turns to steam.or2. Water hose that connects to pee hole comes off and fills engine case with water.Almost seems like the pee hole becomes clogged somehow at high throttle.Anybody have an idea why this is happening? We changed the impeller last summer, with very little use since then. And, like I mentioned, tell-tale stream is good at low throttle.Thought about drilling a hole in the side of the case and sticking the water hose straight out the side - bypassing the pee-hole.Thanks in advance for any help.Jason
  #2
Old July 28th, 2004, 07:51 PM
btatum btatum is offline
Default Re: No Tell-tale stream at high throttle - Mariner 15HP
better drop the lower unit and ck the water pump impeller, very possible it has cracked or split to the point that at idle the suction created to bring the water into the pump housing is low therefore it will pump, at higher rpm's instead of pulling water into the pump it will cavitate and not pump water. as for the hose, i would just replace it and use small zip ties to secure it.
  #3
Old July 28th, 2004, 10:53 PM
emckelvy emckelvy is offline
Also check the thermostat if so equipped. Sounds like something's salted up or plugged up.The only reason for the hose to blow off the telltale is if there's debris in the plastic telltale fitting, causing a stoppage which builds up pressure. Try backflushing the telltale or blowing back with air, with the water hose disconnected from the telltale.I've seen motors so full of silt, sand, & debris that the stuff was constantly breaking off the insides of the water jacket, then going out and plugging up the telltale. Had to remove the cyl block water jacket cover (the one over the spark plug holes) and clean it out.Note: your Mariner, if it's a Yamaha motor, may have a cyl head and not a water jacket cover, the diff would be very apparent by the size of the bolts holding the head/cover on; head bolts would be quite a bit larger. Also the head's a lot thicker than a cover would be.HTH........ed
  #4
Old July 29th, 2004, 08:51 AM
phatmanmike phatmanmike is offline
i had same thing with my 115 merc, turns out, i took 'er apart and she was FULL OF SAND wich was imeding the flow at higher rpms... just a thought
  #5
Old July 29th, 2004, 10:58 AM
Thanks very much for all the replies. Sounds like I have some work to do!
  #6
Old July 29th, 2004, 12:33 PM
KCLOST KCLOST is offline
Let us know what you find...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tell-tale stream temp Dead Eye Mercury & Mariner Outboards 5 June 13th, 2006 10:39 AM
no tell tale water stream bnz897 Mercury & Mariner Outboards 6 June 9th, 2006 04:54 AM
No tell tale stream tikka Mercury & Mariner Outboards 5 March 23rd, 2005 01:34 PM
tell tale stream blown67 Mercury & Mariner Outboards 6 July 9th, 2004 05:54 PM
water tell tale stream Darian F. Johnson & Evinrude Outboards 2 April 4th, 2004 06:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
