  #1
Old July 21st, 2004, 03:48 PM
sdreece sdreece is offline
Default '92 75 hp Mariner - cutting out in mid range only, fouling plugs WOT.
I've had this motor for a few hundred hours or so and I have not changed the way I run it.I noticed a sluggish / cutting in/out (like a miss) when accellerating or trying to hold at less than WOT (between 1500 and 3500 RPMs). It starts, idles and runs wide open like a charm.I took out the plugs and found them to be verry carbon/oily, so I replaced with new plugs, used fresh gas with 2+4 stabilizer, but then after about 2hours of WOT (or close - no idleing) I removed the new plugs and same thing (black and sticky). The thermostate seems to be working and I tried a completely separate fuel system (remote tank) and same problem.. any suggestions??
  #2
Old July 22nd, 2004, 08:16 AM
99tango 99tango is offline
Default Re: '92 75 hp Mariner - cutting out in mid range only, fouling plugs WOT.
Could be time to rebuild the carburetors. It sounds like they are dumping too much fuel into the engine.
  #3
Old July 25th, 2004, 09:41 PM
fun123fun321 fun123fun321 is offline
Hi 99tango: Do you think rebuilding the carb will fix my problem too? I have a 1993 Mariner 50hp. The motor would run at full throttle for awhile. sometimes 5mins, sometimes 30mins. then bogs down. When that happens. I would put it to idle and slowly throttle it. The motor would slowly move up to 1500 - 2000rpm, then start to bogg down again, but ocassionally it would recover and runs fine for awhile then boggs again. I removed the plugs and found them kinda wet with blackish on the tip. I replace them with new ones. Then it would run fine for a bit(1mins+). I've rebuilt the fuel pump, new gas tank and cable gas/oil mix ratio 1:50(quick silver prem). Could it be the carb,stator,plug wires? I have the manual, but no help. Your help is greatly appreciated.Thanks in advance.
  #4
Old August 3rd, 2004, 03:36 PM
Quote:
Originally posted by 99tango: Could be time to rebuild the carburetors. It sounds like they are dumping too much fuel into the engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fouling plugs glenngamblin1 Johnson & Evinrude Outboards 4 May 21st, 2004 06:36 PM
plugs fouling bshores Mercury & Mariner Outboards 0 May 3rd, 2004 06:07 PM
Fouling Plugs 16Pilot Johnson & Evinrude Outboards 2 April 10th, 2004 07:13 PM
mariner 200 fouling plugs blueraven Mercury & Mariner Outboards 3 July 26th, 2003 04:06 PM
Plugs keep fouling cowboy67 Johnson & Evinrude Outboards 6 July 17th, 2001 06:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
