  #1
Old July 18th, 2004, 03:03 PM
mtelow mtelow is offline
Default Uneven exhaust note/Miss/ 2001 Mercury 40 hp 2 stroke/Is this normal for a 2 str
We just purchased a 2001 13 ft Sport Boston Whaler with a 2001 Mercury 40 hp 2 stroke(2 cylinder with a single carb). Listening to the exhaust note, I can hear a miss that is more noticable at idle, but is still there even through mid range. Idle speed in gear is 850 rpm and about 1100 in neutral. If you try and set the in gear idle speed to 750 rpm it tends to quit. The motor also shakes a bit in gear and at idle but smooths out as power is applied. I have cleaned the carb, set the oil injection, put in new plugs, changed the gas and oil, and played with the air mixture with no avail. Compression was 125 in each cylinder. there is not much time on it. The engine does not bog and runs right up to 5500 rpm. The motor is still under extended warranty so I brought it in to the local Mercury repair shop. He set the timing and adjusted everything but it still sounds the same. He mentioned this is just how the 2 strokes run. Is this true? My 6 hp on our canoen idles smooth with no noticible missing sound. Is it just the bigger outboards that do this or is it the 2 cylinder, 1 carb, setup? Could it be something in the CDI ignition like low voltage or bad coil? We just bought the boat and the original owner thought it was running a bit more rough since he put it away. Any help would be greatly appreciated. Thank you......
  #2
Old July 18th, 2004, 03:08 PM
phatmanmike phatmanmike is offline
Default Re: Uneven exhaust note/Miss/ 2001 Mercury 40 hp 2 stroke/Is this normal for a 2
what you have sounds excellent. be happy it runs as good as it does....\i take it this is your first 2 stroke outboard... yes, 2 strokes arent always smooth, and especial an inline 2 cylinder... the more cylinders, the smoother they run
  #3
Old July 19th, 2004, 07:55 PM
bump
  #4
Old August 2nd, 2009, 04:47 PM
whyboats? whyboats? is offline
Default Re: Uneven exhaust note/Miss/ 2001 Mercury 40 hp 2 stroke/Is this normal for a 2 str
sounds pretty normal to me. 2 strokes idle that way and run a little choppy at low speeds. My 80 hp merc is the same way. never could tune or adjust it out. one guy said that they have to run a little rich at low speeds to get the proper mix at high speeds. go have alot of fun with it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 Mercury 9.9 4-stroke feetdown Mercury & Mariner Outboards 10 April 6th, 2006 10:21 AM
Mercury 2001 four stroke efi lacey bluedog Mercury & Mariner Outboards 1 September 10th, 2005 10:09 AM
Uneven exhaust at Gimbal 3 L Merc / Alpha 1 after engine repair hzerr Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 November 20th, 2004 08:13 AM
2001, 50hp mercury 4 stroke...... fzc77 Mercury & Mariner Outboards 1 September 6th, 2004 06:11 PM
2001 75hp 2 stroke Mercury Wauna-Op Mercury & Mariner Outboards 1 April 16th, 2002 06:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
