Re: Shift shaft pulled up when lower unit was dropped
Okay, I won't use those words...but last summer I found milky lube in my lower unit (73 Merc 500). Took it to my boat guy. The "kid" in the shop said he could replace the leaking shift shaft seal in a few minutes. He pulled the shaft out, replaced the seal and put the shaft back...exactly what you ARE NOT supposed to do. His dad, a shop mech, had to fix it for me by tearing into the lower and putting things right again. Just had the entire lower unit resealed for $300. I think your hosed bro.
