I runs good at high speed but stall's at low speed's. With Warm-up lever at full overly fast but when you pull lever to mid point or lower it dies then you must choke it to start it agian. It act as if it is out of gas but bulb is tight. Do you think idle curcuit is clogged or idle mixture needs to be adjusted? Buying motor with boat he said he had motor rebuilt. Used deep creep so far.
