  #1
Old July 8th, 2004, 07:18 PM
rjsizemore rjsizemore is offline
Default 1985 90hp mercury loss of power
I have a 90 mercury just dont have the power to get out the hole that it use to have. Have good spark on all cylinders compression is 135-140 on all 6 cylinders. This motor has never had a rebuild its all orginal except I put a staor trigger and new switch boxs. This engine is on a 15.8 fiberglass fishing boat it has a13x21p prop it has had this size prop since new. I dont have a tach so dont know how many rpms I am turning but it seems to run as fast as it always did before just loss of power coming out of the hole. Would a rebuild help me? What kind of price range am I looking at.
  #2
Old July 9th, 2004, 06:29 AM
Default Re: 1985 90hp mercury loss of power
Should I just buy a new engine or fix my old one.
  #3
Old July 9th, 2004, 09:21 AM
Chris1956 Chris1956 is offline
RJ, If you have the compression you cited in your post, there is no fundamental reason for the lack of power. I recommend you determine if a cylinder or two are fouling at idle and clearing out at high speed. I had this happen to me once, due to a leaky fuel pump diagram. While idleing, the bottom two cylinders would "load up", and not fire until I had gotton on plane.
  #4
Old July 9th, 2004, 01:41 PM
I forgot tp list I have installed a eletric fuel pump 4psi witch helped a little I just dont understand this motor.
  #5
Old July 10th, 2004, 05:28 PM
would my reeds have anything to do with my problem.
  #6
Old July 10th, 2004, 07:57 PM
What kind of job would it be to change the reeds
  #7
Old July 11th, 2004, 06:49 AM
ronmold ronmold is offline
reeds are not that hard but with compression as high as you state it is likly the hours on your motor are quite low and reeds should be in good condition. Bad reeds will have blowback that you can feel by putting your hand in front of the carbs when cranking it over. Have you done a de-carbonizing on it yet? Run a couple of cans of Sea-Foam through it.
  #8
Old July 11th, 2004, 06:58 AM
jimmbo jimmbo is offline
Location: Edmonton Alberta(land of rightwing nuts), Canada
Replacing the reeds on an inline 6 is a major job and requires complete disassembly of the powerhead.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 Evinrude 60hp loss of power mike66 Johnson & Evinrude Outboards 4 August 29th, 2005 06:21 AM
1985 force 125 power loss checklist fmf Force & Chrysler Outboards 3 August 15th, 2005 07:47 PM
90hp yam w/ power loss iwhitevt Yamaha & Suzuki Outboards 2 November 11th, 2004 02:08 AM
85' 90hp mercury power loss rjsizemore Mercury & Mariner Outboards 17 May 26th, 2004 02:47 PM
1985 Mercury 50HP Power Loss kayjay Mercury & Mariner Outboards 0 July 7th, 2003 08:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
