  #1
Old July 5th, 2004, 06:46 PM
we2sail we2sail is offline
Default 1993 Mercury 8, Neutral Low speed Idle quits, Forward & Reverse work just fi
1993 Mercury 8, Neutral Low speed Idle quits, Forward & Reverse work just fineIn neutral Low speed Idle quits, Forward & Reverse work just fine. OB has been reworked twice by mechanics and problem persists. Last OB mechanic said that a "U" shape arm in the idle assembly (?) needs to be replaced. However, I have been waiting since last August (2003). Either he forgets or else his excuses work better than he does or the part may be hard to find for this "low volume production" OB.I have a manual, and the part appears to be the "Primer lever"; however the symptoms for a bad prinmer lever don't match my observation. The engine "tends" to flood if I over choke it, and the "Idle Speed" is unchanged by turning the Idle Speed Knob. And, as stated, once in Forward gear I can get my 10 foot dinghy up on plane with no problem and my fat butt (215 lbs).I have a "long past" background in Auto engine (Gas & Diesel) hobbyist expertise. Is this part difficult to replace and if known; to aquire from some Merc parts supplier ?TIA(advTHANKSance)Bob
  #2
Old July 7th, 2004, 07:33 AM
weimy weimy is offline
Default Re: 1993 Mercury 8, Neutral Low speed Idle quits, Forward & Reverse work jus
have you had your idle speed turned up?
  #3
Old July 7th, 2004, 04:39 PM
Thanks,Yes, the idle set was checked.// Bob
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
7.5 hp Merc tiller, forward, reverse, no neutral jon_boat_boy Mercury & Mariner Outboards 1 December 28th, 2006 07:15 AM
Wont go into neutral or reverse, stuck in forward shute421 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 July 11th, 2006 04:00 PM
motor runs in neutral only - no forward or reverse tightline Johnson & Evinrude Outboards 2 June 25th, 2006 09:07 AM
Engine Stalls when shifting from Forward to Neutral or Reverse to Neutral jules03 Johnson & Evinrude Outboards 6 May 10th, 2006 07:21 AM
1979 70 hp mercury stalls when putting in forward or reverse from neutral bnbad11 Mercury & Mariner Outboards 11 February 24th, 2006 02:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
