  #1
Old July 5th, 2004, 01:48 AM
pumpkin head pumpkin head is offline
Default mariner 75 no fire on cylinder #1
Be grateful for any help from any experts out there:Engine: Mariner 75 ELPTO 1995 2 stroke, 3 cylinderI changed the stator since the engine would not start and traced the problem to an open circuit on the low charge coil. Engine ran great for 3 or 4 days......Now i have a problem.The no 1 cylnder is not firing (diagnosed by sequential removal of HT leads. It produces a healthy looking regular spark but the cylinder will not fire. I stripped the carb and cleaned and reassembled but still no improvement(it looked pretty clean). The trigger coil ohm tests looks fine as do the primary and secondary coils. If i am getting a spark could the pack be dodgy or it more likely a fuel problem? Is there an easy test for this?I dont have a peak voltage meter. How can i be sure if its electrical or fuel?Any help greatly appreciated! Thanks
  #2
Old July 5th, 2004, 04:02 AM
Elmer Fudge Elmer Fudge is offline
Default Re: mariner 75 no fire on cylinder #1
Do a compression test on all cylinders and post results.
  #3
Old July 5th, 2004, 08:18 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Connect an inductive pickup timing light and run it. If the light flashes, the sparkplug is sparking. You can check any cylinder this way. I'm with Elmer on this. I think your problem lies elsewhere.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #4
Old July 6th, 2004, 08:07 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Did you swap a known good spark plug into that cylinder and try again? Plugs have been known to fail like this.Chris.........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #5
Old July 6th, 2004, 12:47 PM
Thanks a million chaps. Problem solved. I checked the compression seemed ok(approx 100psi each cylinder). Started the engine on each single cylinder to verify no 1 bad, then swapped around the coils- Number 1 coil would not fire no 2 cylinder. No 2 coil fired no 1. Pretty conclusive. Thanks for all your help. A happy pumpkin head.......
  #6
Old July 17th, 2004, 11:40 AM
Keith Buchanan Keith Buchanan is offline
I have exactly the same problem at the moment but I was discounting the coil because of the healthy looking spark I am getting.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
intermitten fire on third cylinder kembry Mercury & Mariner Outboards 5 June 20th, 2006 07:06 PM
1985 Evinrude VRO 140 one cylinder won't fire rauletta Johnson & Evinrude Outboards 16 August 11th, 2005 07:57 PM
top cylinder won't fire panelspec Johnson & Evinrude Outboards 0 July 7th, 2004 06:09 AM
Cylinder miss fire plus+ Johnson & Evinrude Outboards 3 June 19th, 2004 10:30 AM
no fire in one cylinder dwhudson Johnson & Evinrude Outboards 23 March 29th, 2004 04:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
