  #1
Old July 4th, 2004, 02:16 PM
PGURNS PGURNS is offline
Default 79 Mercury 50HP power trim pump leak
The trim pump on my 50HP Merc. is leaking. It is leaking from the part that is bolted to the pump, I am assuming this is a valve body of some sort. If looking at the unit from the front, the leak is on the right hand side of the valve body. It appears to be coming from a hole about 1/16 inch in diameter. Is this a vent hole of some sort? Is there supposed to be a welch plug or something in it? (there are no threads in the hole).When topped off with fluid it works just fine until all the fluid leaks out. Also what is the reverse lockout function on the unit do?Thanks Paul
  #2
Old July 4th, 2004, 04:58 PM
luv fishing luv fishing is offline
Default Re: 79 Mercury 50HP power trim pump leak
ok first onmy 50hrs merc,on the cylinoid side, comeing from the big lines i have one hole that is 1/4 in. that is not pluged. all the rest are about 1/16 in. have small alan head plug in the rest of them. now on my tilt/trim it has a label that reads:Reverse lock operation. to release turn knob full right, to engage turn knob full left. CAUTION - DO NOT run boat unless lock is engaged. use sae 10w30 or 10w40. fill to bottom of fill plug theads with unit tilted up. the number on my pump is 76395A1. hope this is helpful.
  #3
Old July 4th, 2004, 05:15 PM
Yeah the hole I'm talking about is on the side where the big lines come off of. It is sort of facing up almost where the motor meets the valve body. it looks as though there may be a spacer plate or something there too. Thanks for the reply I will try and take a picture of the area and post itPaul
  #4
Old July 4th, 2004, 05:38 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Paul,If the leak is coming from between the valve body and the pump reservoir, then one of the 'o' rings has failed. There are 2 sets of 4 'o'rings that seal the passages between the 2 units. No big deal to remove and replace. Hope this drawing helps. Chris...........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #5
Old July 4th, 2004, 05:39 PM
here is the best picture I could take of the thing
  #6
Old July 4th, 2004, 05:41 PM
Chris, the leak is actually coming from a hole in part number 8 in the diagram.In fact the hole is almost exactly where there the line coming from the number 8 is pointing to. Thanks for the diagram.Paul
  #7
Old July 4th, 2004, 05:50 PM
on mine the hole is there but nothing in it.
  #8
Old July 4th, 2004, 05:52 PM
Thanks smaner, at least now I know something did not just fall out of it. I'll bet I have some o rings leaking internally or something.
  #9
Old July 4th, 2004, 09:01 PM
achris's Avatar
Paul,That 'hole' is just the way the casting is. Your leak is somewhere else, that's just where the fluid reaches the outside world. My bet, 'o' rings Chris...........
__________________
  #10
Old July 6th, 2004, 05:29 AM
I had a feeling the leak was from an internal o ring. I am going to take it aprt tonight and see what's going on in there.Thanks for all the inputPaul
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Johnson 50hp Trim/Tilt Fluid Plug leak drJ Johnson & Evinrude Outboards 4 January 15th, 2007 06:27 PM
Power Trim leak? (milky overflowing trim fluid) hal2814 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 December 5th, 2006 10:54 AM
Tilt/Trim Pump Leak dorchard Mercury & Mariner Outboards 3 September 12th, 2005 07:31 PM
1979 mercury power trim hydro.pump rdg73 Mercury & Mariner Outboards 3 June 3rd, 2005 12:58 PM
mariner tilt and trim pump leak delprof Mercury & Mariner Outboards 1 July 21st, 2003 08:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
