good evening (its evening in london)
I bought a 11' inflatable with a 13.5hp 4stroke mariner in spain a couple of years ago. The dealer told me that it was really a restricted 17hp but spanish law allows a maximum of 13.5hp due to local licencing laws. Now, i was reading the owners manual and it seems there are 3 models all different HPs but all have the same bore and stroke. When I serviced the engine the following season, I removed restrictor which sits between the carb and manifold; a 1/4" plate with a half moon shape in line with the venturi. The took it out on the water and the boat now jumps onto plane in a fraction of a second. The point of all this is that it now seems to be overrevving although I don't have a rev counter. After reading this gr8 forum, I reckon I need to find a higher pitched prop to keep the WOT revs down. Not sure about this though, any comments?? Also after removing the restrictor, do I need to change the jets in the carb as it may be runnign lea
Any ideas on the subject much appreciated
thanks
chris
