  #1
Old June 21st, 2004, 10:55 AM
marinerman marinerman is offline
Default 1996 60h mariner trouble starting
I have a 1996 60h mariner outboard that has troubles starting after being tilted up. I have to pull start it to get it going. After it is tiltrd down it electric starts no problem everytime. I think it may get flooded when tilted up but why does pull starting it bypass and fix this annoyance?
  #2
Old June 21st, 2004, 11:20 AM
Elmer Fudge Elmer Fudge is offline
Default Re: 1996 60h mariner trouble starting
I believe that it should be started in the downward tilted position only.
  #3
Old June 21st, 2004, 11:28 AM
I do start it in the downward position. The problem is after it is tilted up, it will not start in the downward position unless I pull start it. It will start everytime after that while down.
  #4
Old June 21st, 2004, 11:44 AM
Check the wiring from ignition to the starter motor for any sign of corrosion,also around the battery terminals.
  #5
Old June 21st, 2004, 12:47 PM
here's the the answer to my problem. When the motor is tilted up then put back down, the ignition terminal connector to the starter comes loose due to the tightening of the power cable leading from the motor to the egnition key. I found that depending on whether or not the motor is turned to the left or the right directly effects the ability to start. If I have the motor turned to the right it starts no problem. If I have the motor cranked to the left, the ignition cable tightens up and comes loose at the connection.Why it seemed like pull starting it fixed it is when I put the cover and housing back on, I unknowingly reconnected the loose connection. I wonder what a outboard mechanic would have charged me for that problem? Sometimes it is the most simple of things to fix the most complicated problems
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 merc 50 hp trouble medic4511 Mercury & Mariner Outboards 2 July 4th, 2006 10:26 AM
trouble starting apocripha Force & Chrysler Outboards 8 April 27th, 2006 02:26 PM
1996 40 hp mariner compression trouble logname Mercury & Mariner Outboards 12 April 27th, 2005 08:45 PM
Mariner 6hp 1996 starting problems Nidri240 Mercury & Mariner Outboards 8 March 2nd, 2005 10:32 PM
Having trouble starting stewbedoo Non-Repair Outboard Discussions 4 June 20th, 2003 10:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
