help me i need help with my mercury 50 1979
99jf2
i have a 1979 mercury 50 i have a spark but nothink happens can you help quick
dilligafda
Re: help me i need help with my mercury 50 1979
Is there fuel on the spark plugs or are they dry? What condition are the cylinders in? Do you have good compression? Is the spark on time? Check for the basics and let us know. ;)
rickdb1boat
Mix up a spray bottle of pre-mix and try to start the motor while shooting some pre-mix into the carb throats. If it fires, you most likely need to rebuild the carbs or at the very least, get new hoses from the tank, including the primer bulb. You are pumping up the primer bulb first and using the choke when you try to start it, right?? Has the motor been sitting for a while? More info, please.
99jf2
the engine has been sitting for a while? <br />what else can it be do u know where the timing is set from get bac thanks
roscoe
You really should check out the entire fuel delivery system, and the compression before messing with the timing.
greasemonkeyozi
Go to NAPA and buy you a can of SEA FOAM DEEP CREEP and spray some in the carborators while motor running. You said that the motor has been sitting up so I would figure that fuel has gummed up in your fuel system in time, sea foam is good for that. If that doesnt work, consider having your carbs and fuel pump rebuilt. Rebuild kit for fuel pump is around $5.00.
fhughes
Bentley, Try putting new spark plugs in first. A lot of times when a motor sits for a while, all you need is new plugs.
