I recently purchased a 1995 boat with a Mercury 40 horsepower outboard with power tilt/trim. The boat has not been used the past two years. The engine runs fine but the power tilt will not lift the engine. While depressing the tilt up switch I can manually lift the engine only about 1/4 of what it should tilt. The tilt motor sounds as if it is operating properly but the motor will not lift.
