Re: Flywheel removal 84 mariner 90hp
The puller threads down the big hole on top of the fly-wheel, then bolt is threaded down anther hole in the center of the puller, which pushes on the crank (actually on an aluminum spacer that comes with the tool so you don't muck up the crank), and pops the fly-wheel up... (usually with a pop..)<br />It is a mercury special tool, and can probably be purchased at your local deal, and maybe even online somewhere..<br /><br />Scott..
