serial #b288620 3 cyl.motor from 1980's.Primer bulb does not get firm.There is a gas filter that looks just like a car oil filter in the fuel line between the tank and the motor.Even after the motor has warmed up and I am on the water it does not always start up quickly.It has started back up eventually, but only does so after repeated attempts and some combination of moving the fast idle lever to max and pumping the primer bulb. This is not safe as during this dely the boat often drifts a good distance out of control.
