  #1
Old May 28th, 2004, 08:30 PM
cnefalcons cnefalcons is offline
Default Mariner 40 ELO won't stay running
Need help please! 40 ELO serial nbr 6EGL451266Engine starts easily but will only run approx 60 seconds then dies. Have replaced fuel pump, fuel bulb, hose and engine connector, have cleaned fuel delivery lines to carbs, drained carbs all to no avail.Ignition side all appears fine. Want to get a manual but am unsure of year, dealer advised it was 89 or 90, problem is that is the year the manual changes!Any suggestions on getting engine to run and year would be greatly appreciated. Thanks
  #2
Old May 29th, 2004, 06:41 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: Mariner 40 ELO won't stay running
Try putting a piece of clear hose in the line somewhere. If you see air bubbles start working back from there. I have seen a fuel tank with a crack at the top of the pickup (inside the tank), that would prime ok but wouldn't run, because the crack was too small to allow enough air into the system when large amounts of fuel were drawn (priming) but would allow air in with small demand (when running the engine). Or try another fuel tank.Your engine is 1987 and the service manual is the same from 1977 to 1987, the full production range of this engine. It's part number is 90-84520-2. You'll probably find the serial number is 6E9-451266 (the 9- looking like GL). This was the last of the 'Yamaha' Mariners. The next Mariner 40 was a Mercury and appeared in 1994 as the Marathon. Chris.........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old May 29th, 2004, 11:06 AM
eurolarva's Avatar
eurolarva eurolarva is offline
I would rebuild the carb. IF not at least check the float to see if it is correct. Does the bulb get firm without gas seeping out of the carb?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
will not stay running russeller Johnson & Evinrude Outboards 11 May 26th, 2005 08:45 AM
doesn't stay running ryan04 Johnson & Evinrude Outboards 1 April 12th, 2005 03:51 AM
mariner 40 wont start, or stay running dannymoe69 Mercury & Mariner Outboards 3 July 23rd, 2004 05:02 PM
1998-5 HP Mariner won't stay running eb77 Mercury & Mariner Outboards 0 June 16th, 2003 12:49 PM
Will not stay running new boater Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 18th, 2002 01:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
