  #1
Old May 27th, 2004, 05:20 PM
Edpowers Edpowers is offline
Default 75 Mercury Marine Electric
Great forum -- I searched -- and used many hints, but now I'm stumped..three years ago I bought a used "Mercury Marine 75 Electric" - that's what it says on the cover...I think it's only 7.5 hp -- it ran for a year of river boating, about 5 trips -- then I put it in the garage -- added water remover and fuel stabilizer-- and last June had it serviced by Harrisburg Seaplane Base- they did plugs, points and gaskets -- it ran at home easily with a water connection, but I never used it -- end of summer I left it hooked to gas and again put in water remover and fuel stabilixer. Now I tried to start it today -- after I cleaned the plugs and tidied up some of the wiring that looked frayed by putting new insulated wire in. Engine has this # - 74918 - in raised letters on the left side, looking from front to the water. On the round cylindricalpiece on the right side are the white numbers 06 23 77. It won't start -- after I cleaned the plugs and made sure the gas was getting from the tank to the carburetor, I choked and pulled and choked and pulled -- after @ 40 pulls, and a squirt of gas into the spark plug holes, it popped once..but immediately died. subsequent 40 pulls and chokes left me with sore arm and belly and a blister. Harrisburg Seaplane base won't even look at it -- they say their new policy is not to work on engines made before 1985 -- Big Bee, another big boat place, told me I can bring it in, but they won't get to it until July -- spark plugs are dry when I take 'em out -- I put carb cleaner into the jail-house plastic bar in front of the carburaetor, sprayed WD 40 into spark plug holes, then put a few drops of oil in each and pulled the cord a few times without the plugs in....I tapped the bottom of the carburetor -- not too hard -- I'm not super-engine savvy -- the gas does get to the carb, I took the plastic piece off and squeezed the bulb -- the vent on the tank is open.somehow, I don't think gas is getting to the firing chamber --------------- and the ELECTRIC on the cover always puzzled me -- what electric? OK -- too long a post -- but that's my tale of woe -- I looked at prices on a new 6 hp engine and almost died -- I paid 900 for boat -- 14 ft v aluminum and trailer and motor three years ago -- ouch! on new motor prices -- seems to me I'm missing ann elementary point, but I can't find it -- Perhaps someone could provide some suggestions...Much thanks edpowers
  #2
Old May 27th, 2004, 05:25 PM
2springers26 2springers26 is offline
Default Re: 75 Mercury Marine Electric
needle is probbly stuck.. try squeezing the primer ball real hard to pop it loose.. other wise you need to dissasemble, clean & replace
  #3
Old May 27th, 2004, 05:37 PM
Thank you -- I think I have to disassemble aqnd clean the carburetor..right? I did squeeze the h*** out of that ball, then stopped when I read postings that warned me I might destroy the thin filter pieces -- I'll try it again in the am -- thanks EDpowers
  #4
Old May 27th, 2004, 05:43 PM
andrewkafp andrewkafp is offline
Are you sure it's not the fuel pump ?
  #5
Old May 27th, 2004, 05:45 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
First check for spark. This is the easiest test. Plugs out, connected to the leads, laid on the top of the engine and get someone else to pull the cord. If you see spark (good solid blue ones) on both plugs then move to the carb. To verify a carb problem, after you have confirmed spark exists, squirt a small amount of fuel in the plug holes, reinstall the plugs and start plulling. It should fire and run for a couple of seconds, then die. This will confirm you have a carb problem.Good luck.Chris.............
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #6
Old May 27th, 2004, 06:13 PM
Thanks to both -- no, I'm not sure it's not the fuel pump -- and don't know how to test for it -- tomorrow AM i will test for spark plug firing - my wife can puul and I'll watch for flame -- thanks for instant feedback...Edpowers
  #7
Old May 28th, 2004, 07:46 AM
Ahha -- the sparks do have flame -- so it's not gettin' gas -- I have to wait until after the holiday to work on it again -- I'm going to put carb cleaner in it..and tap it a few times before I attempt to remove the carburetor -- much thanks Edpowers
  #8
Old June 3rd, 2004, 05:06 PM
Thanks to the people who responded -- after squirting carb cleaner into the carb and letting it sit two days -- then tapping the carb as hard as I thought it would take...and trying to start it again and again --- I did have spark -- and clean fuel -- I gave up -- Lakeside Marine in Harrisburg has it -- they say they are only a week behind -- very courteous reception, unlike Harrisburg Seaplane base, who seem a bit upscale and hoity-toity -- ball park estimate is $150to $200 --- ouch! how does one find the small service shops that repair outboards without a $45 per hour labor charge? -- I wish I was more mechanically inclined, but my simple tools just wouldn't 'fit" to let me disassemble the carb..............thanks again for the instant help -- ed
  #9
Old June 4th, 2004, 01:36 PM
Gus Mortimer Gus Mortimer is offline
$45/hr is alot better than where I am! Still I dont like to pay if I dont have to. Another favorite saying of mine is it never hurts to have more tools! for what you might pay that mech you could get some tools that "fit". Just a thought, on the other hand my garage is getting kinda full.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1150 Mercury Marine sylvanken Boat Topics and Questions (not engine topics) 4 January 7th, 2006 09:35 PM
Mercury Marine WHAT IS IT? can only find serial# fishon71 Mercury & Mariner Outboards 9 December 4th, 2005 05:11 AM
mercury marine madmarlin Mercury & Mariner Outboards 5 November 10th, 2005 03:08 PM
95 force 70 by Mercury Marine no go fluidshooter Force & Chrysler Outboards 6 March 8th, 2004 12:56 PM
Mercury Marine jegervais Non-Repair Outboard Discussions 12 January 10th, 2004 10:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
