1999 200 mercury efi-tilt/trim motor will run in down position of switch. nothing when you try to raise in up position. where is the relays and is this the common solutio?
Hi,<br />Relays(2) are on starboard side of engine.(you can follow wire from tilt-trim switch on hood(engine)<br />check for bad fuse or bad working of relay<br /><br />Tirett
