Same thing happened to me last year, I was told spun hubs 'just happen' like flat tires. And you won't be able to spin it by hand, it will look normal. My symptoms exactly the same as yours, try to throttle up and RPMs run away. If you nudge it up you can get maybe 1500 rpm out of it.
If it's a good prop you can get a new hub pressed in. If not, go for a new prop. Remove that fishing line, it can wreck the seals and let water in where there shouldn't be any.
