  #1
Old May 22nd, 2004, 10:33 PM
Oldsaltydog Oldsaltydog is offline
Default 1998 Mercury 90HP Stalling at Slow Speeds
Starts easily, idles fine, runs really well, except it sometimes stalls while running in gear at around 1100-1200 rpm, and the primer bulb usually goes soft. But it will start right up after the bulb is primed. Seems like a fuel starvation issue. Any suggestions? (Cleaned carbs, new fuel filter, new plugs, and rebuilt fuel pump.)
  #2
Old May 22nd, 2004, 11:41 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: 1998 Mercury 90HP Stalling at Slow Speeds
Silly thing to say, but have you checked that the tank vent is open?
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old May 23rd, 2004, 04:50 AM
Yes, it's open. Thanks for responding.
  #4
Old May 23rd, 2004, 12:07 PM
bryanredfish bryanredfish is offline
Sounds like the low idle jets are clogged. May be time for a carb job.
  #5
Old May 23rd, 2004, 02:28 PM
2springers26 2springers26 is offline
primer ball& fuel pump update need to be done on ALL motors Built 2000 & older....( new fuel arre effecting old style parts) if your carbs are Clean do the fp & p ball update....
  #6
Old May 23rd, 2004, 06:11 PM
Wellcraft 89 Wellcraft 89 is offline
2springers,do you want to fill us in on what your saying.is there a service bulletin on this?????Rich
  #7
Old May 23rd, 2004, 06:40 PM
I'Ve attended many mercury training schools in the past 4 years.. the # 1 preach Is primer ball & fuel pump update... all Motors Built 2000 & older Should have the new primer balls( yellow rib on it)& square fuel pumps rebuild with new Kits... the new fuels of today are eating the rubber parts... fp// check valves are now clear plastic not rubber... I probbly find 5-10 boats a week that are Not laying flat... Most comon complains run ruff.. seems to flood, won't idle... If the valves are not flat... That cyl will flood.. for less than $25.00 In parts it well worth the update...
  #8
Old May 23rd, 2004, 10:12 PM
Thanks 2springers26 for your reply. I have already rebuilt the fuel pump -- including the clear plastic check valves. And I will certainly buy a new primer bulb!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
90hp Mercury slow out of the hole lifeboatman3 Mercury & Mariner Outboards 9 June 12th, 2006 06:30 AM
1998 Force Mercury 90HP Stalls at Slow Speed Oldsaltydog Force & Chrysler Outboards 3 May 23rd, 2004 10:39 PM
Stalls at very slow speeds Hink Johnson & Evinrude Outboards 2 June 15th, 2003 08:55 PM
4.3 OMC SLOW speeds mohogg Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 May 30th, 2003 07:51 AM
1998 Mercury 200HP Bluewater Stalling/Sluggish Odyssey Mercury & Mariner Outboards 2 April 23rd, 2002 04:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
