  #1
Old May 16th, 2004, 06:11 PM
rjsizemore rjsizemore is offline
Default 85' 90hp mercury power loss
I engine is very slow getting on a plane with just me. Will not plane with 2 people. This engine is on a 15.8 fiberglass fishing boat. The stator trigger both power packs have been changed new sparks plugs. This engine is an inline 6 compression ranges 125 to 130 psi except #3 is 118 could anyone help with my engine does it need rebuilding how much would it cost
  #2
Old May 17th, 2004, 09:32 AM
Fishin4fun Fishin4fun is offline
Default Re: 85' 90hp mercury power loss
I have a complete 90hp powerhead with 142-148 lbs in all cyls, she runs great. Let me know if you are interrested. I will make you a sweet deal on her! and can have her delivered to your house in time to be on your boat this weekend.
  #3
Old May 19th, 2004, 09:35 PM
Clams Canino Clams Canino is offline
Prop it to make 5500 WOT with just you aboard.Max advance set to 21 degrees.Throw a can of Mercury power tune through it.-W
  #4
Old May 23rd, 2004, 12:44 PM
well i dont have a tach so I cant really tell the rpms but doesnt seem to run like it should. Seems to me its not getting enogh fuel it will idle fine but if you put the throttle down fast it boggs and quits. the primer bulb still hard after this happened it is about 2 weeks old. Could my fuel pump be the problem I took the hose off while it was running and their was very little coming out is this normal or is their another way to check the fuel pump.
  #5
Old May 23rd, 2004, 04:57 PM
how can I check my fuel pump
  #6
Old May 23rd, 2004, 04:58 PM
  #7
Old May 23rd, 2004, 07:08 PM
Gus Mortimer Gus Mortimer is offline
check fuel pressure at top carb with fuel pressure tester.
  #8
Old May 23rd, 2004, 07:15 PM
NathanY NathanY is offline
Compression on that motor is fine, does not need rebuilt. Sounds like to me that you just need to have the carbs cleaned, or rebuilt.
  #9
Old May 23rd, 2004, 07:20 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
The IL6 90 hp should only be propped to 5000 rpm. They don't have the porting to cope with higher revs. Have you checked the usual suspects? Spark on all cylinders, firing on all cylinders, advancing the timing correctly, all carbs opening together, no choke shutters closed?Use the KISS principle? (Keep It Simple Stupid)Chris..........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #10
Old May 25th, 2004, 05:14 AM
rollnover rollnover is offline
Quote:
Originally posted by Clams Canino: Prop it to make 5500 WOT with just you aboard.Max advance set to 21 degrees.Throw a can of Mercury power tune through it.-W
  #11
Old May 25th, 2004, 05:17 AM
I might be interested in that powerhead. what is a sweet deal? How much
  #12
Old May 25th, 2004, 05:41 AM
Hey you with the powerhead! you say you are from southern NH. I need you man. I have an in-line six the runs real bad. But it runs. how can I drop it off to you? Where are you?
  #13
Old May 25th, 2004, 08:15 AM
I have the powerhead, but I am not from NH. Email me at edward.abrahamson@us.army.mil and I will talk with you if you are still interrested.
  #14
Old May 25th, 2004, 11:36 AM
jimmbo jimmbo is offline
Location: Edmonton Alberta(land of rightwing nuts), Canada
Had this happen to me too. Sounds like a dead cylinder or two. Check the plugs for spark. If not the problem, then see one or more of the carbs has a stuck float. Pukes fuel out of the bleeds when primer bulb is squeezed.
  #15
Old May 25th, 2004, 01:32 PM
if i messed with the throttle linkage would it mess the timing up I screwed it in alittle so it would idle better
  #16
Old May 25th, 2004, 06:59 PM
Do you mean the idle stop, the timing advance limit, the linkage between the ignition plate and the carbs?
  #17
Old May 26th, 2004, 01:22 PM
i messed with the one going to the throttle cable
  #18
Old May 26th, 2004, 02:47 PM
I doubt any adjustment on the throttle cable will cause your trouble, it might make the idle inconsitant or the shifting stiff. I think you have a bad switchbox.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 90HP VRO Loss of Power swab Johnson & Evinrude Outboards 5 June 15th, 2006 08:07 AM
90hp Tohatsu loss of power mikep9927 Honda & Tohatsu/Nissan Outboards 6 May 29th, 2005 06:30 AM
90hp yam w/ power loss iwhitevt Yamaha & Suzuki Outboards 2 November 11th, 2004 02:08 AM
1985 90hp mercury loss of power rjsizemore Mercury & Mariner Outboards 7 July 11th, 2004 06:58 AM
90hp sportsjet power loss damage inc Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 August 3rd, 2002 04:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
