  #1
Old May 15th, 2004, 04:32 PM
5string 5string is offline
Default 2002 125 mercury steering
I have seen all the posts about the steering rod being frozen in the tilt tube, which is my problem. I took the cable loose and unbolted the arm on oposite side. I was able to tap it in but there is nothing to tap it back the other way? Also, what holds the cable to the rod, when I loosened the nut at the end of the cable where it conects to the tilt tube , I was able to turn the wheel left and the whole cable moved but the other side where it bolts to the arm is still frozen? That tells me it came unconnected inside the tube or it is broken?
  #2
Old May 24th, 2004, 06:45 PM
OFF_SHORE OFF_SHORE is offline
Default Re: 2002 125 mercury steering
Any update on the situation? I have the same problem and could use some first hand info. I can't figure out the problem either so any help would be greatly appreciated.Thanks
  #3
Old May 28th, 2004, 09:29 PM
MURX MURX is offline
guys, how did you make out? shop can't take mine forthree weeks gotta fish
  #4
Old May 28th, 2004, 11:58 PM
hondon hondon is offline
The engine end of that steering cable is a telescoping rod with the large end attached to the tie bar and the small end at the large nut at the tilt tube.The large end is a tight fit inside that tilt tube and most outboards use only steel for that tubes construction so when corrosion happens inside that tube it chokes the movement of the large end of your cable.Frozen steering.Disconnect the tie bar and the large nut and with a SOFT AND I MEAN SOFT ,hammer give the tie bar end of that cable a few hardy smacks and see what happens.No access to do this ? Sometimes you need to pull the engine off to fix this.
  #5
Old May 29th, 2004, 10:00 AM
Just took another gander at it........tried persuading it with a block of hardwood, and a hammer NO GO! where should I put the dynamite?
  #6
Old May 29th, 2004, 10:04 AM
Should I just cut the cable and try to drive the remnants starboard to port?Do the big black nuts have to be removed to drive the cable or rod out of the tube
  #7
Old May 30th, 2004, 10:40 AM
So where does the dynamite go
  #8
Old September 25th, 2009, 10:19 AM
Gutz's Avatar
Gutz Gutz is offline
DID I FIX IT - Or did I break it?
MURX:
I'm no mechanic - but I recently had to deal with this same problem on my old 120 O/B before going out.
I loosened the big black nut and "hit" the other end with the big rubber hammer while dripping 3in1 oil on the exposed part of the rod. At first, I got nowhere, then I decided to use the steering wheel (and a buddy) and a "bigger" hammer...
Good News: The rod finally came free and I was able to lube it up and go fish....
Bad News: After performing this emergency surgery I created a bad spot dead center in the wheel (where the rod was originally stuck) when turning hard across the middle...I get nothing for second... then it catches and steers normal. This occurs steering in either direction at any speed only at dead center.
QUESTION for the real Mech's out there: Is my steering on borrowed time or is this a minor nuisance I'll have to live with?
Thanks for your replies
__________________
There is nothing in life more worth enjoying than just messing about in boats.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2002 Tohatsu steering issues? Johnshan1 Honda & Tohatsu/Nissan Outboards 5 April 7th, 2006 09:55 AM
2002 90 hp mercury dbavery Mercury & Mariner Outboards 2 July 23rd, 2005 01:44 PM
2002 YAM F115 Steering stinkylinky Yamaha & Suzuki Outboards 2 July 13th, 2005 10:15 AM
2002 Mercury 115 Maine-Basser Mercury & Mariner Outboards 6 September 30th, 2003 11:30 PM
2002 40 Mercury NaturalLight16oz Mercury & Mariner Outboards 1 April 22nd, 2003 01:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
