  #1
Old September 11th, 2005, 10:42 AM
Cruzomatic Cruzomatic is offline
Default New boat owner, have many questions.
Hi, I'm new to boat owning but not new to boats and have many questions. Please forgive if some have been asked before, just need some reassuring. Just purchased a new '05 Caravelle 207 with Volvo Penta 5.0 220hp.Should I leave the transom in the up or down position while stored? A buddy of mine who has owned his "ski ray" for 12 years tells me he never uses fuel stabilizer. Is it necessary and how long should the boat sit before having to use it if at all? Should I tow with the cover on or off? Are those transom clips recommended while in tow or at any time? Lost my anchor(heavy debris down there or something) yesterday, was one of those rubber coated heavy ones. Purchased it by the advice of my dealer, should I replace it with the same one or would the metal variety work? Any other new boat owner advice would be appreciated, thanks.
  #2
Old September 11th, 2005, 11:47 AM
Wimperdink Wimperdink is offline
Default Re: New boat owner, have many questions.
"Should I leave the transom in the up or down position while stored?"I'm assuming you mean the outdrive.. I've always left mine up so I dont forget to raise it before going boating but others may recommend otherwise." never uses fuel stabilizer. Is it necessary and how long should the boat sit before having to use it if at all?"My opinion would be if it is going to sit for more than a month or two, I'd add stabilizer and run it for awhile before storing it. Fuel that turns to "varnish" in your carbs, can add up to a costly repair bill. why take the chance when its relatively cheap and easy to do."Should I tow with the cover on or off?"If its a good secure cover and you have a long distance to travel, sure why not? I never do but I live 1/2 mile from my launch... if its going to rain I just dont go. If its loose and flaps in the wind much at all, count on it self destructing over time."Are those transom clips recommended while in tow or at any time?"not sure what your referring to."was one of those rubber coated heavy ones. Purchased it by the advice of my dealer, should I replace it with the same one or would the metal variety work?"my $20 walmart anchor holds my 19' just fine and its rubber coated. Wouldnt want a metal anchor dragging up the side of my new boat. (if I had a new boat)"Any other new boat owner advice would be appreciated, thanks."Sure post pictures of your rig... we all enjoy seeing others boats.
  #3
Old September 11th, 2005, 12:38 PM
Thanks for chiming in. Not sure how to post pics yet??
  #4
Old September 11th, 2005, 05:17 PM
craze1cars craze1cars is offline
Here's my take on all this:Generally want to leave the drive down when stored, so the bellows don't get stretched out during the off season...just don't forget to tip it up before towingI use Sta-Bil with every fill-up. It helps everything and hurts nothing except maybe $20 per year out of the wallet. It serves as a carb cleaner and a water remover, I always know it's thorougly in the carb float bowl for storage when the off season comes, if the boat happens to sit for a few months unused it's one less thing to worry about. The fuel is always fresh. General opinions is that new fuel begins to go stale after about 3 months.If your cover is tight and secure, tow with it. If it flaps in the wind, it'll shred to pieces.You're referring to trailering clips, and yes they should be used anytime you're towing to relieve stress from the trim hydraulic system and as a safety net in the event of a hydraulic failure that causes your outdrive to suddenly drag the interstate at 70 mph. Another $20 of cheap insurance to prevent possible $1,000 in damage. No need for them when parked because your drive will be down (see # 1 above).Anchor choice depends on your use. Rubber coated is nice to prevent scratching your boat, but if you're careful not needed. Many people do not understand the importance of a chain on the anchor. You can't just tie a rope to your anchor and expect it to hold. Anchors get their holding power from the weight of the chain PLUS the weight of the anchor. Usually you want chain to be a bit heavier than the anchor. For your rig, you'll probably want 6 to 8 feet of 1/4 inch chain between the rope and the anchor for general anchoring for general daytime use. If you're anchoring in deep waters or overnight/unattended, you'll want something much more significant, do some research from others more knowlegeable about anchoring than I am...Additional advice: Make sure you're legal (lifevests, flares/flags, fire extinguisher, registration, launch permit, etc.), take a safety class, make a prelaunch checklist and follow it, and don't forget the plug.I use www.photobucket.com to post pics. There's many other similar sites. Basically you post your pic to a web URL, then post the URL here on your posting. It's pretty easyWelcome and enjoy your rig!
  #5
Old September 11th, 2005, 07:46 PM
Thanks for the advice. I'll ask the wife for help on posting pics. She's the computer guru in the family.
  #6
Old September 12th, 2005, 08:21 AM
jtexas's Avatar
jtexas jtexas is offline
welcome to iboats...I don't put stabilizer in my outboard fuel, but I never let more than 3 or 4 weeks go by without running it. year round. I don't tow with cover on just cause if it gets loose it'll flap to death & maybe damage something. Rain's no problem, it'll just drain anyway. Also if you're counting on the cover to hold gear in, and the cover comes loose (Murphy's law), you may lose something. Owners of new boats may feel differently, to protect gelcoat from road hazards.I did trailer it covered once, long trip in the rain & didn't want to put it up wet or mess with it when I got there. No problem. Put at least 3 straps over the top of the cover & around under the boat to keep it from filling with air.Don't forget to cross the safety chains under the trailer tongue.Check out www.tpwd.state.tx.us for boater safety tips & state laws. And lots of good info on local lakes & ramps.Ramp courtesy: prep for launch before you get on the ramp: remove tiedowns, put in plug, load gear & beer from truck, don't unhook the bow hook though. Pull clear of the ramp to prep for the drive home. At night, turn off your headlights while on the ramp, they blind other drivers trying to back down the next lane.have fun, and most importantly, be sure to post your Stupid Human Tricks in the SHT forum!
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #7
Old September 12th, 2005, 08:39 AM
timfromfc timfromfc is offline
Take a boaters safety class. Read the forums regularly. You would be amazed at how many tips you pick up.Don't forget to put your bilge plug in every time. I keep mine on a "holster" around my keys. That way I always know to put it in.If you are having troubles and someone gives your grief, remind them that they were new to boating once too! Most of the time, people are very friendly and willing to help if you ask.Have fun!!!
  #8
Old September 12th, 2005, 05:08 PM
Appreciate the kind help guys, take care,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Some questions from a newbie boat motor owner (Johnson 70 VRO) sssports Johnson & Evinrude Outboards 11 January 10th, 2007 05:39 PM
many questions for new owner broncosilver Johnson & Evinrude Outboards 5 February 8th, 2006 08:28 AM
1977 evinrude 70 hp questions from new boat owner reddog349 Johnson & Evinrude Outboards 12 May 25th, 2005 02:25 PM
New owner questions Freezebear Johnson & Evinrude Outboards 13 October 20th, 2003 12:05 PM
First Time Boat Owner - Questions Nacman Mercury & Mariner Outboards 7 July 26th, 2002 06:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
