ross_larter
- Apr 6, 2003
- 109
Hi,<br />On my 1996 mariner 60hp bigfoot 2/s lower unit, there is 3 screws, one at bottom to drain/fill oil, vent hole 8ish inches above it and oil check hole to right of vent screw about 1/2 inch lower.<br /><br />When i fill the unit it takes about 650ml till it comes out the oil check hole(i then put screw in oil check hole), then about another 100ml till it comes out the vent hole.<br /><br />Should it fill the oil till it comes out the oil check hole or all the way to the vent hole. My old 70hp merc only had 2 holes.<br />Cheers<br />Ross
