bergsofafeather
- Aug 2, 2003
- 27
I have a 85 hp 1975 Mercury, s/n: 4722152. The s/n tells me according to a manual that I have the Thunderbolt ignition without distributor. Question is this, on the switch box, there are eight wires going down the right side of lugs, apparently two for each cylinder (in between each pair of wires are the numbers 1, 2, 3, 4). On the number 4 set, the top wire of the two if frayed in a few spots and a little corrosion on the strands that are exposed. Can anyone tell me what this wire is/does, and where to get a replacement, and can I just get a chunk of wire from anywhere if it is close to the same gauge and replace it myself, or do I need to actually replace it with original manufacturer's?
