I recently bought a 175 hp Mariner outboard that only has 20 hrs. from a family friend. The engine was not started in 2 yrs, so I changed the gas, fuel filter, and I added fuel conditioner to the gas. The engine starts up fine, but you have to give it a little gas; however, after running for 15 min or longer if you let off the throttle it will not idle. Instead, it will start to putter until it dies, and then if you try to start it up again it will not start unless you give it some time to sit. I can start it everyday, but I can't start it after it initally runs.
I would really appreciate an help.
