  #1
Old April 24th, 2004, 12:20 PM
Dman Dman is offline
Send a message via AIM to Dman
Default 95 Mariner 60 hp-bogging
Here's what I've done so far...1. New plugs2. Cleaned carbs 2 times!3. New primer bulb4. New fuel filter-old one had some dirt in it5. New gas-19 gals6. Inspected all fuel lines The motor idles great but when I apply the gas it bogs out to the point of almost killing but then I let off the gas and it comes back down to idle just fine and will dile fine. Sounds like it's not getting gas? Or too much gas...?Is there any way to test the fuel pump? May need a rebuild? It'll kinda of surge when I give it gave then bog down. Trying to figure out the problem without taking it in. The motor is hardly used from what I can tell. It's was used 3 times in the last 3 years then I bought it.Thanks a bunch. The opener is 1 week away!!!Dman
  #2
Old April 25th, 2004, 12:47 PM
Default Re: 95 Mariner 60 hp-bogging
Update: Pumping the bulb does not make any difference, so does that eliminate the fuel pump?Plugs look god with a tan color.Cleaned the carbs again!Gas has got to get getting to it. I took out the tank pick line and that's fine too. It is firing on all cylinders.Am I missing something? Could it be electical?ThanksDman
  #3
Old April 25th, 2004, 06:03 PM
Update 2:Took part the fuel pump! The diaphrams are flaking away and cracking. I am guessing that this condition caused the motor to not have enough suction to get the gas to the carbs at higher speed?Dman
  #4
Old April 26th, 2004, 05:34 PM
Well, I put the new fuel pump kit in and it made NO DIFFERNCE whatsoever!!!I'm out of options. Anyone have a clue?????Dman
  #5
Old April 26th, 2004, 07:23 PM
riverebel riverebel is offline
have you checked the electrical parts.i have a 95 60 hp mariner that would run good for about a 1/2 hour then die like it was running out of gas,but would idle.let it sit for awhile and u was good to go again.i noticed when it would do this that the tach would stop working ever now & then & it was overcharging.i put a new regulator/rectifier on it and took it out this weekend to try & so far so good.dont know if the overcharging was causing something to break down or what
  #6
Old April 27th, 2004, 05:20 AM
How do I test some of the electrical componets? When It comes to the electrical, I'm way past my minimal experience.Dman
  #7
Old April 27th, 2004, 06:21 AM
phatmanmike phatmanmike is offline
when you say"cleaned the carbs again" are you actually taking them apart and cleaning the internals or just spraying the cheep stuff through them, if you are sparaying, thats not doing anything
  #8
Old April 27th, 2004, 06:25 AM
Air and carb cleaner. Taken completely apart. All jets and opens are clear of any debris. 100% sure of it.Does anyone know the original idle mixture screw setup? How many turns out per carb? Could it be as simple as that? It idles great and doesn't kill when I put it into gear.
  #9
Old April 27th, 2004, 05:00 PM
Well, it's out of my hands now. Brought it to a dealer to look at. Maybe a switchbox? I told him what I've done so far and he 'thinks' it could be electrical.Later.D
  #10
Old April 27th, 2004, 05:08 PM
keep us posted as to what it was
  #11
Old May 2nd, 2004, 09:42 AM
Got the boat back and it was a fairly simple fix. Spun hub on the prop. I would have never found it. I should have known. I switched props once and it went great. Put the old one back on and went like crap, which started this whole thing. The opener was yesterday in WI. Kinda cold and windy but I've seen it worse!!Later...Dman
  #12
Old May 2nd, 2004, 10:56 AM
muskixer22 muskixer22 is offline
I've been scoping out this forum for a couple of months. I think its awesome. I have a '95 Mariner 60hp Bigfoot that started bogging just like yours.Started the third season a owned it. Took it toMerc dealer. Rebuilt 3 carbs. No better. They'suggested' switchbox. Replaced switchbox andran like a champ for two seasons, but last year itstarted bogging again. It runs like an old Ford LTD. I started running 93 octane and it ran a little better. Ended last season with it bogging.Then I found this site. Everything I've read hereindicates electrical. Probably switchbox. Somebody (Clams) please tell me bogging has nothing to do with the prop. I'm no mechanic,but a 'spun hub' doesn't make any sense.
  #13
Old May 3rd, 2004, 05:30 AM
I'm not an expert either but sure enough it was the problem. They said the motor was in excellent condition with no other problems. Maybe someone can explain why a spun hub will not let the motor rev and cause it to bog? Sure would be appreciated.Dman
  #14
Old May 4th, 2004, 01:29 PM
Explorer 4x4 Explorer 4x4 is offline
Would someone be kind enough to explain what a "spun hub" is please?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
60 hp mariner bogging down riverebel Mercury & Mariner Outboards 9 October 12th, 2008 11:56 PM
Mariner bogging down approaching full throttle Jaybird244 Mercury & Mariner Outboards 5 December 23rd, 2004 06:11 PM
40 HP Mariner Bogging Down rsimms Mercury & Mariner Outboards 4 March 7th, 2004 07:36 AM
Mariner 100hp bogging on top end vucelick Mercury & Mariner Outboards 8 May 11th, 2002 07:50 AM
Mariner bogging down slider Mercury & Mariner Outboards 3 February 24th, 2002 05:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
