  #1
Old April 21st, 2004, 07:16 PM
wahoo1 wahoo1 is offline
Default Lower unit removal- 125 Mariner Offshore
I'm trying to remove the lower unit from my 1998 125hp Mariner Offshore long shaft. The manual says to put it in neutral then to loosen the jam nut above the shift coupler and to turn the coupler until the two halves loosen. Then to remove the nuts and pull the lower unit free. I can't seem to find the jam nut or coupler. I tried removing the nuts but the unit wasn't going to come off with out force. I would appreciate any help. Thanks
  #2
Old April 23rd, 2004, 09:02 AM
dilligafda dilligafda is offline
Default Re: Lower unit removal- 125 Mariner Offshore
Are you using the Merc manual? According to my infor there is no jam nut above the coupler. That one should just be a splined coupler between the upper and lower shift shafts. Remove all the bolts from the gearcase and lower the gearcase. (Make sure you remove the trim tab and the bolt below that too!) If it doesn't lower, a little gentle persuasion with a prying tool may help. Otherwise, soak the coupler with a good quality penetrating oil (I use PB Blaster) and let it sit overnight and try again.Good luck!
  #3
Old April 23rd, 2004, 01:17 PM
quantumleap quantumleap is offline
Master Chief Petty Officer
I don't think there is a bolt beneath the trim tab. It's right in front of the tab.
  #4
Old April 25th, 2004, 02:10 PM
Thanks for the help. I removed the lower unit today. Just 5 nuts and a dozen blows with a board and rubber mallet and it slid off. Changed the water pump and put it back on and everythings working great! I was using the Seloc manual. Must be a misprint. Thanks again.
  #5
Old April 26th, 2004, 06:23 PM
fidnee fidnee is offline
wahoo, if you get this can you email me at nyfire@frontiernet.net, I have a question similiar to yours. dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Lower unit removal LuckyPenny Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 January 16th, 2006 04:28 AM
Mariner 60 - Lower casing removal Dave Walton Mercury & Mariner Outboards 1 August 21st, 2005 02:36 PM
Mariner 25 lower unit removal icacos Mercury & Mariner Outboards 0 July 31st, 2002 09:41 PM
mariner 25 lower unit removal icacos Mercury & Mariner Outboards 0 July 31st, 2002 09:35 PM
1996 Mariner 75 HP Lower Unit Removal jhs449 Mercury & Mariner Outboards 1 May 12th, 2002 08:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
