  #1
Old April 18th, 2004, 11:29 AM
Peter019fishing Peter019fishing is offline
Default Mercury 20hp convert to electric
I have a older 20hp I'd like to install electric start on. I don't know the year but s/n is 5186081. Compression is too strong for my dad to pull. Any insight would be great. Thanks
  #2
Old April 18th, 2004, 02:59 PM
Mettaree Mettaree is offline
Default Re: Mercury 20hp convert to electric
Year is 1979. Hard part is finding a flywheel with a starter ring on it that will work. Does it have the mount for the starter? I have not been able to find one for myself - have tried a few tho. Good luck.
  #3
Old April 18th, 2004, 04:59 PM
andrewkafp andrewkafp is offline
Peter.. Just curious, but why do you want to go electric for a 20hp ? I can understand it for a bigger motor which takes a lot of strength to start, but not normally on a 20?
  #4
Old April 19th, 2004, 06:05 AM
Andy,Too much compression for my dad now that he is 74!
  #5
Old April 20th, 2004, 05:01 PM
dcm3372 dcm3372 is offline
Hi,I just did the electric start conversion on my 1980 30HP Mariner - it's not a cheap thing to do...Here's some things to consider that I hope will help you :Battery charging - if you don't have this already on your outboard you'll need to fit it (if available). You can make do without if you're prepared to charge the battery before a day out and you can start it manually if the battery goes flat.Toothed flywheel - If your flywheel has no teeth around the perimeter it'll be additional cost to change it over.Motor mounting - even engines that could support electric start didn't always have motor mountings (mine didn't). If not you might need to get a bracket.Solenoid - you can't wire the starter directly through a push-button. It must go via a marine quality solenoid or the button will burn out.That said, I'm very pleased with the conversion. The 30HP is well within my capabilities to pull-start but when seated at the front of the boat it was very inconvenient to climb back to start the engine and was a worry in case it ever stalled.Any other info you need I'd be glad to help you out.Good luck!
  #6
Old April 21st, 2004, 10:32 AM
Thanks Dan and All who responed. After calling several places it would appear that this venture is a lost cause. It would be nice to come up with a decompression valve that one could open upon start-up then close.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Can I convert a QD-23r to electric start? PatrickGlose Johnson & Evinrude Outboards 1 January 24th, 2006 04:29 AM
Can I convert a pull start to electric? SliderM72 Yamaha & Suzuki Outboards 4 June 30th, 2005 05:22 PM
73' 20hp convert to wheel steering- - - - - - ryanc Mercury & Mariner Outboards 0 April 20th, 2004 05:24 PM
convert to electric starter amoser Johnson & Evinrude Outboards 2 March 1st, 2004 11:17 AM
Convert to electric start 35hp ????? roscoe Johnson & Evinrude Outboards 2 August 26th, 2003 09:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
