  #1
Old April 15th, 2004, 06:56 PM
Dman Dman is offline
Send a message via AIM to Dman
Default '95 Mariner 60--running on 2/3
Just took the boat out for the first time since I've owned it. Idled fine but would bog severely when hitting the throttle. Got the boat home and began to investigate. When running the boat with the hose hooked up, I'm fairly certain the bottom cylinder is not firing. I can take the cap wire off and it does not change the idle. I took the either of the top 2 cap wires off and it would die---leading me to believe the bottom cylinder is not firing. The lower cylinder does not get warm either.The plug shows no sign of firing. I can take hold the cap against the plug and it does spark but maybe not strong enough....Any help is appreciated.Dman
  #2
Old April 16th, 2004, 12:35 AM
roscoe's Avatar
roscoe roscoe is online now
Default Re: '95 Mariner 60--running on 2/3
Switch two of the coils around, swap the top coil with the bottom coil. Now check to see if the top plug is firing. Hopefully it is just a bad coil. Not too expensive to replace.
  #3
Old April 16th, 2004, 05:34 AM
I'll give it a try and get back....Dman
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
93 MAGNUM 40 MARINER ...RUNNING HOT RICKYC53 Mercury & Mariner Outboards 16 January 13th, 2007 10:53 PM
Mariner 150 still running HOT. rocks Mercury & Mariner Outboards 8 July 10th, 2005 05:54 AM
94, 40 Mariner not starting after running OK JQF Mercury & Mariner Outboards 0 May 13th, 2004 07:44 AM
82 mariner 90 hp running weird jamescody Mercury & Mariner Outboards 8 August 14th, 2002 09:28 PM
20 hp Mariner running bad gprestridge Mercury & Mariner Outboards 5 May 21st, 2002 03:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
