  #1
Old April 6th, 2004, 08:21 PM
Skinner123456789 Skinner123456789 is offline
Default Mercury 125 new noise
I have a 2001 Mercury 125 on a 17' 1" Champion boat. I have ran this boat with no problems until I put it in the shop for a recalled trailer issue. While it was in the shop I told them to refinish the prop for me (I asked if they could get alittle more speed out of it) I use to run about 4900 rpms WOT, 52-53 mph. This was the 1st day to run the boat for me and it was running about 5100 to 5150 rpms WOT with the same 52-53 mph, I was watching the tach so much that I might be running to many rpms I sudenly look at the Speedometer and it read 45 mph. well I didnt think to much about it till I came up to my fishing hole on idle. My partner and I noticed a whinning noise so I took it out of gear and it had the same noise. (Like some thing was grinding or rubbing in the engine) I stoped and fished for a while so it cooled down. Started it up and it sounded fine made it to the boat ramp and it started it again. I loaded it on the trailer and checked to see if the lower end was hot but it wasnt. Does any one know the max rpm for a Merc 125, I think it is 5250 but not sure. Could this noise be related to the prop work or just concidental and something else. Thanks for all your help in advanceSteve
  #2
Old April 6th, 2004, 10:50 PM
Josh Knapp Josh Knapp is offline
Default Re: Mercury 125 new noise
on your 2001 it may be new enough that it says on the serial number sticker on the transom clamp bracket. it may not be new enough. mercury started doing that recently but I am not sure when they started.josh
  #3
Old April 7th, 2004, 03:56 AM
Mettaree Mettaree is offline
Josh: On my '96 200hp WOT is listed on the transom bracket as you say.
  #4
Old April 7th, 2004, 07:11 AM
quantumleap quantumleap is offline
Master Chief Petty Officer
Yes, the WOT RPM range is 4850-5250. Check for clearance between the prop and lower unit. Check to make sure the thrust washer is installed correctly. What pitch prop are you running?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Knocking Noise when decelarating (Mercury 115) TNarky Mercury & Mariner Outboards 6 July 23rd, 2006 08:40 AM
90hp Mercury Engine noise JayDee Mercury & Mariner Outboards 0 July 26th, 2004 05:22 AM
1999 Mercury 150 Optimax clicking noise Valv Mercury & Mariner Outboards 1 July 23rd, 2003 05:23 AM
Noise in top of motor, Mercury I-6 1000 Doug Watson Mercury & Mariner Outboards 7 December 18th, 2002 10:48 AM
Mercury 40 Four Stroke BigFoot Noise haggertb Mercury & Mariner Outboards 5 June 14th, 2002 01:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
