  #1
Old April 2nd, 2004, 12:20 PM
harleyman124 harleyman124 is offline
Default 1987 mercury 8hp...tan/grey foam from exhaust-pics
1987 Mercury 8hp..tan ooze coming from idle exhaust ports (both holes) and very smoky. It idles fine, but when revved up it smokes badly. The top spark plug is wet, the bottom one is dry. I swapped the coils but got the same result on the plugs. I adjusted the idle screw, have new gas and the right ratio mix. The reeds look good too. The water pump is working fine...its a little slow to pump initially, but works good once it starts flowing. Any ideas?Added..I have pics of the ooze
  #2
Old April 2nd, 2004, 12:31 PM
phatmanmike phatmanmike is offline
Default Re: 1987 mercury 8hp...tan/grey foam from exhaust-pics
send me pics, i have had similar prob, but lemme see before i start preachingphatmanmike@yahoo.com
  #3
Old April 4th, 2004, 08:39 AM
Is this leaking powerhead seals?....Cracked block?...Anyone?....
  #4
Old April 4th, 2004, 10:09 AM
Virago85 Virago85 is offline
send pic to eugene1e@earthlink.net
  #5
Old April 4th, 2004, 06:01 PM
andrewkafp andrewkafp is offline
I have seen a similar post here before, where the gunk came from excessive trolling, and was running out of the 2 exhaust holes.Here is post.. Motor is almost the same as yours.. Vintage wise. http://www.iboats.com/cgi-bin/ubb/ul...;f=29;t=011030
  #6
Old April 5th, 2004, 01:12 PM
updated with pics!!!!!
  #7
Old May 10th, 2004, 12:27 PM
jimcanniff jimcanniff is offline
Harleyman,Did you ever figure out what was causing that grey foam to leak from the exhaust?My father has a 1987 9.9 Merc that just started doing pretty much the same thing. The gear oil is leaking from the exhaust like yours but gets sprayed everywhere. Plus there is water in the chamber where we fill the lower unit oil.Any idea would be appreciated, thanks.-Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
DT140 1987 Suzuki leaking carbs? 'PICs jgrisham02633 Yamaha & Suzuki Outboards 4 April 10th, 2007 04:21 AM
1987 8HP - Is this exhaust normal? gmiller1951 Mercury & Mariner Outboards 2 April 14th, 2006 06:51 PM
Sea Foam or Mercury Product Koffi Force & Chrysler Outboards 3 March 27th, 2006 12:03 PM
1987 Merc 3.0 lower unit water problems (with pics) Roady1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 11th, 2004 06:41 PM
78 Merc 1400 outboard grey sludge out the exhaust? mrrrl Mercury & Mariner Outboards 1 June 30th, 2002 09:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
