Re: Mariner 220 Magnum EFI too much smoke. ODDD1 help please.
Here is an update on this problem for anyone with similar problems. I gave up trying to fix myself and took to dealer. They said one of the switch boxes I had installed was bad. I told them to change whatever needed to be and about $680 later I got the boat back. They set timing and changed out the switch box was all on the invoice. I was a little sceptacal since I had done a DVA check as best I knew how with a Merc DVA. Finally got it to the lake to test it out this weekend. Ran great from start up to shut down. No smoke, hardly any even at startup. Would idle in and out of gear just fine and easily hit 35 mph at 5000 rpm. Still had some lung left, but decided not to push it on the first time out. So, money well spent in my book with todays outboard costs. Hope this helps some one else decide what to check and do.
