Boilermaker
- Sep 28, 2003
- 388
A little Background>>>1971 18Ft Modfied Vee hull/Deep bow? 7'+ beam >>>Fresh 1978 Johnny 115.<br />Engine originally had OMC Factory ALUM. 13.5 x 19 prop (uncupped) Had good holeshot & pulled skier up on 1 ski.>>Spun the hub & installed newer Johnson cuped ALUM.14.25 x 19>>killed holeshot & only 4800RPM W.O.T.<br />Switched to a used ALUM. 14.25 x 17 cupped factory prop> good performance 5300rpm WOT.<br /> Got STILLETO #21317>>13.25 x 17. This has killed the holeshot. WOT is bearly 5000 with the trim way up, almost venting! Once it gets on plane it goes like hell, but getting on plane takes a while. The Engine hight is all the way down with the bottom of the cav plate abt 1/4" below the hull bottom.<br />The boat has been fully loaded every time with the stilleto, but about the same load as when I used the 14.25 x17 Alum.<br />Will raising the "X FACTOR" help with the holeshot??? I know the rpms should be higher, but the undercarrage of the boat is saturated & I plan on redoing the stringers & deck in the spring. I figure I am carring a few hundred pounds of water in the wood. That alone should increase a lot of the performance.<br />I'm just wondering why such a differance between the Stilleto Prop 13.25 x17 & the Factory 14.25 x 17???
