  #1
Old March 23rd, 2004, 07:48 AM
jtrbug jtrbug is offline
Default 60 hp Mercury,Water Pressure?
Anyone have an idea how much water pressure I should have on my "99" 60 hp merc outboard. Just put a new impellor kit in it and it appears to be working fine. Would like to install a water pressure guage but what psi scale do I need? 0-15psi,0-30psi. Any answer would be appreciated.
  #2
Old March 23rd, 2004, 09:22 AM
dilligafda dilligafda is offline
Default Re: 60 hp Mercury,Water Pressure?
Well the service manual says the water pressure should be 12-15psi at wide open throttle, if that helps. Good luck!
  #3
Old March 23rd, 2004, 11:43 AM
Thanks Dilligaf for the reply. Think I'll put a 0-30psi gauge on it. At least the needle wouldn't get pegged. I bought a manual and couldn't find anywhere what kind of water pressure the pump might develope. Thanks again.
  #4
Old March 23rd, 2004, 12:51 PM
Merc805 Merc805 is offline
My 50hp puts out about 7-8 PSI at WOT. I think 12-15 may be a bit optimistic for a 60!!!My manual says 4-10 at various speeds. The big bangers go close to 20..
  #5
Old March 24th, 2004, 04:19 AM
Thanks Merc805 for your reply. I think I'll remove a vent/drain plug in the waterjacket over cylinder head and place a temporary pressure gauge in it to see what water pressure it has before I buy one to put in dash. Thanks again.
  #6
Old March 24th, 2004, 06:57 AM
Kenny Bush Kenny Bush is offline
12 to 15 psi should at WOT should give you ample amounts of cooling water. I would get the 0 to 15 guage. It will be easier to read. You most likely will not peg the needle. Besides, anything over 15 is gravy on the cake. The 0-15 guage will better show your pressure drop due to impellar wear/fin break/blockage.
  #7
Old March 24th, 2004, 07:35 AM
Thanks Bushcat for your response. I'll try my temporary gauge first. I definetly don't want a gauge that will read on the low end of it's scale. You're right about impeller wear,ect... Hopefully the weather will be decent here to try it out this weekend.
  #8
Old August 15th, 2008, 08:10 PM
SunTrackerPB21 SunTrackerPB21 is offline
Quote:
I just bought a SunTracker 21Pontoon w/ 2005 Merc/Tracker 'BigFoot' 60 on it. Went for our first run on the lake yesterday and at WOT (5000 RPM) the Water pressure is reading 16 PSI
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp mercury water pressure indicator perchjerker Mercury & Mariner Outboards 27 May 28th, 2009 10:00 AM
Water pressure ( 2000 Mercury 200 EFI ) jashou2003 Mercury & Mariner Outboards 4 May 24th, 2006 05:16 PM
New Mercury 50 2 stroke 3 cyl water pressure Hyper Mercury & Mariner Outboards 7 September 12th, 2003 10:17 AM
mercury outboard low water pump pressure/excessive smoke and unburned oil walleychaser Mercury & Mariner Outboards 2 July 12th, 2003 09:36 AM
Mercury XR-4 low water pressure cgarnett Mercury & Mariner Outboards 0 June 15th, 2003 07:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
