"He said it is a factory defect/problem and that they should be torqued at 18 fp but are only registering 12 fp."
Not likely a factory defect. Considering that the bolts are subjected to a constant heating and cooling cycles, it's not suprizing to me that they were a few lb.ft. off of factory spec. It's the same heating and cooling that requires some bolts to be retorqued after an engine has been run through a few cycles.
With that being said, I don't recall seeing a 125 (or any other engine)fail for that reason alone. One thing I have seen is a cylinder not firing causing water to enter the cylinder through the exhaust and scoring the cylinder. Have your friends technician check the ignition system over.
Good luck and keep us posted!
