1977 Mercury 1150 ser# 4701703 has been setting up 5-6 yrs. Had a tune up and serviced prior to setting by a pro, but guy I got it from never used it, didn't winterize it or unhook gas ect. We have rebuilt fuel pump, removed carbs and cleaned them, put in new water pump (old one looked good), drained old gas. Motor has good blue spark to all plugs. It appears the carbs are not sucking air as you can hold hand over them and not feel suction. We have sprayed fuel in plug holes and in carbs, motor will hit and has fired maybe for a second. Seems like it wants to run. Top two plug don't appear to be wet as the bottom four. Upon hand choking gas will run out front of carbs. Suspect reeds are stuck as carbs were gummed up. By-passing disassembly down to the in-take what is involve in taking the in-take off to get to the reeds. Does anyone have any suggestion / procedures before going this route. Someone told me the motor had to be split to get to the reeds. Is this true? I'm trying to weigh my options at this point. Thanks for any info.
