  #1
Old March 15th, 2004, 10:36 AM
Seminoe Chad Seminoe Chad is offline
Default Mercury 125 spring prep
I didn't winterize my boat(I know shame on me). I did put Stabil in the fuel tank and put the motor down to drain it, but that was it. What do I need to do before getting it on the water, hopefully in the next 2 weeks. It did start after awhile after I went out and played with it over the weekend.
  #2
Old March 15th, 2004, 10:56 AM
KCLOST KCLOST is offline
Default Re: Mercury 125 spring prep
Didn't winterize it, and you live in Wyoming!!!!!SHAME,SHAME,SHAME...Anyway, run the motor on muffs, check to make sure that the water pump is performing properly (it might be a good idea to replace the impeller if you don't know the last time it was serviced). Check for leaks around the water jacket gaskets (hopefully there wasn't too much water left in there to freeze and expand). Drain the lower unit oil and replace with new. Go buy new thermostats if you're not sure they are working properly.... New spark plugs might also be in order. Fogging the cylinders won't hurt anytime (I bet your still freezing in Wyoming). After that you should be good to go...Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Spring Rewind Assembly for 1975 Mercury 40HP jasonjanise Mercury & Mariner Outboards 1 July 17th, 2006 10:00 PM
Recoil spring spring sliped into can StillFishin' Johnson & Evinrude Outboards 2 July 20th, 2004 07:35 AM
Git Rot Prep tailgunner Boat Restoration and Building 6 April 8th, 2004 07:28 AM
79 mercury 175 spring checkup wilswe70 Mercury & Mariner Outboards 2 October 3rd, 2003 10:16 AM
Spring Prep TROLLING Boat Topics and Questions (not engine topics) 9 May 11th, 2003 05:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
