Re: 50hp 4 stroke Mercury - 2000 model
Thanks for your reply. I probably should try and explan whats happening better. When the engine is going the gears change reasonablly smooth, both forward and reverse with the propeller spinning freely. With the engine turned off, and in neutral it spins free. In forward,a racheting can be heard rotating the prop clockwise, turning the prop anticlockwise the engine turns over. In reverse, both ways turns the engine over.
