  #1
Old March 12th, 2004, 05:27 AM
swebb0071 swebb0071 is offline
Default tachometer problems on 92 Mariner 150
I just had my tach replaced and connections redone but my tach is not working properly still. It will register at idle just under 1000, when I hit it to plain off it will rise but as soon as i am level it tachs out then back to 0 and doesnt register again until I turn key off and on and repeat. Any suggestions???
  #2
Old March 12th, 2004, 06:24 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: tachometer problems on 92 Mariner 150
See if you can borrow a known good tach and that will tell you if the tach is bad. It happens even with a new one..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old March 12th, 2004, 07:15 AM
It is a new tach....Bedee. I thought that the other one was bad because it was doing this and put this new one in and the same thing is happening.
  #4
Old March 12th, 2004, 10:18 AM
gaugeguy gaugeguy is offline
Hi Swebb, what is the 6 digit part number on the tach that begins with 9? Sounds like something other than the tach is bad, and the wrenches here should be able to help you. I can verify the tach is compatible with your engine from the part number on the label(on Monday). Have a good weekend.
  #5
Old March 18th, 2004, 01:21 PM
Bedee tachometer....941895. If this is the correct tach what should the setting be 1,2,3,or 4. Thanks again for the help.
  #6
Old March 19th, 2004, 06:41 AM
TampaTom TampaTom is offline
I belive your tach signal is coming from a rectifer that changes a/c current from the stator to d/c current used for systems. If this goes bad, you will have problems with the signal. Sometimes its a combined rectifer/regulator (preventing overcharging). You might have two regulator/rectifers (2x20amp in parralel.) If thats the case, you can switch the lead from the top r/r (grey wire) to the unused lead comming off the bottom r/r and confirm if your problem is the rectifer or the tach.
  #7
Old March 19th, 2004, 08:25 AM
I will check this out. Can anyone verify what the setting on the back should be? 1,2,3,4 ?
  #8
Old March 19th, 2004, 09:25 AM
Which ever coorisponds with "12 pole". Its probably 4.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Quicksilver Tachometer settings for Mariner DavidStonehouse Mercury & Mariner Outboards 3 March 13th, 2005 05:48 AM
tachometer for yamaha / mariner 55 el jurgenscraft Electrics, Electronics and Trolling Motors 1 December 28th, 2004 12:21 PM
Sea Ray Tachometer on a Mariner Outboard mattyc Mercury & Mariner Outboards 0 April 28th, 2003 12:48 PM
merc/mariner tachometer wiring mike b. Mercury & Mariner Outboards 3 March 14th, 2002 07:26 PM
Tachometer for Mariner ausrys Mercury & Mariner Outboards 1 November 7th, 2001 11:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
