Re: Shift rod stuck on 1970 Merc.50
Chapman256, If you have the lower shift rod out, and if it has a spline on the bottom,( I'm not remembering right now,) but if it does, yes you'll have to dissamble lower gearcase to insert the shift rod back into the shift lug,also you have to take out the shift shaft bushing,seal assy. Install a new snap ring on the shift rod, insert into shift lug in lower unit and reinstall bushing assy. If you are going to keep this engine you should purchase a manual for it, it will really help you work more confidently and precisely, plus it will tell you all about your engine and you will enjoy it more. good luck
