  #1
Old February 10th, 2004, 07:29 AM
sullymate sullymate is offline
Default water pump replacement mariner 135 hp-1997
I have the repair manual and have read it. one question, does the shift rod have to be disconnected or will the shift rod just slide out when all bolts are removed and the lower unit is dropped? or is there a bolt that holds the shift rod in place underneath the powerhead? Also it is a cam-shift model so should it be placed in forward gear before work is started? Also i want to install a water pressure gauge, the directions say to locate the plug in the water cooling jacket. I see a brass plug on the water jacket with an "F" shaped plastic part with 2 hollow male ar coming out of the plug. obviously the plugs are not open or being used. Is this the connection for the water pressure gauge? thanks for any info you can give me. Sullymate
  #2
Old February 11th, 2004, 09:07 AM
KCLOST KCLOST is offline
Default Re: water pump replacement mariner 135 hp-1997
The shift shaft will disconnect right above where the lower unit connects to the drive shaft housing. The upper shift shaft will not fall out but it can be pushed upward when you reattach the lower unit. You need to be careful to line up the splines on the lower shaft into the upper or you could push it up and never get them attached. I like to use a shim of some kind to place above the shift linkage where the upper shaft attaches. This helps to keep it from moving upward and makes the installation easier IMO.I think the plug where the pressure guage fitting will go is at the top of the block right behind the outer edge of the flywheel. It's a plug that measures 3/4 or 19mm in diameter (actually 1/2" pipe thread). I'm getting ready to install one on my motor.I'm not really following your description of the "f" shaped plastic thing. My installation is to remove the plug (mine has no plastic piece), install a 1/2" male to 1/8" female brass bushing reducer, install an elbow into the bushing and attach the hose to the elbow.Here is a good link to installation instructions on several motors. http://www.tflx.com/PDF/99376.pdf
  #3
Old February 11th, 2004, 12:03 PM
JB's Avatar
JB JB is offline
Moving to Merc/Mariner Troubles.
__________________
RED SKY at night. . .
JB
  #4
Old February 11th, 2004, 01:28 PM
Thanks for your advise KCLOST. I appreciate your help.
  #5
Old February 11th, 2004, 04:17 PM
robalofish robalofish is offline
The "F" shaped plastic thing may be the enrichment valve. If so it should have one of the hose nipples connected to the carbs. the other one is open to the atmosphere. If this is the enrichment vale you would not want to connect the w/p guage to it. Just a guess on my part.RFish >()>
  #6
Old February 11th, 2004, 04:24 PM
rodbolt rodbolt is offline
hello yep I tend to agree with ya robalofish. I make my own plugs from the existing fitting. if its the 1/2 pipe then drill into one of the flats and tap it 1/8th pipe. or you can buy it from merc. good luck and keep postingif ya try to make your own mark the flat that faces aft so your fitting will face aft when you reinstall it.
  #7
Old February 13th, 2004, 06:47 AM
thanks robalofish, that F shaped valve by the heads is an enrichment valve with 1 tube going to the carb. thanks for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'94 Mariner 25HP water pump replacement fish56 Mercury & Mariner Outboards 15 March 25th, 2007 07:37 PM
1997 Force 40 Water Pump Chaney101 Force & Chrysler Outboards 4 January 31st, 2007 10:07 PM
Water pump 1997 mariner 60hp friedlobster Mercury & Mariner Outboards 0 August 22nd, 2006 11:42 PM
water pump replacement mariner 135 hp-1997 sullymate Non-Repair Outboard Discussions 2 February 11th, 2004 12:03 PM
Evinrude 90 Hp (E90ELEC) 1997 - Replacement of water pump len_b Johnson & Evinrude Outboards 4 February 21st, 2002 02:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
