  #1
Old January 31st, 2004, 10:01 AM
90merkdoesnotalwaystart 90merkdoesnotalwaystart is offline
Default 90 H.P. Mercury w/jet drive does not start after warmed up
I have a 1987, 3 cylinder, 90 H.P. Mercury Outboard with a jet drive. Operation in lake or river: Motor will not start after being run initially on cold start up or after being run for a while and shut down hard to restart with warm or hot engine. With hose attachment in yard: Motor starts every time. I have heard the impeller in the jet drive needs to be reshimed to alleivate this problem, but need more info. regarding this. Appreciate any help. rws
  #2
Old January 31st, 2004, 10:14 AM
Clams Canino Clams Canino is offline
Default Re: 90 H.P. Mercury w/jet drive does not start after warmed up
Is that a 3 or a 6 cylinder? 1987 was the changeover for the 90's.IF it's the six, a leaky exhaust plate can be a a known culprit. If you're getting water in the cylinders, fix it before damage escallates. Also they cool off pretty fast, try a cold start on it.If it's the 3 cylinder 90, OR a jet drive issue, someone else can take it from here.-W
  #3
Old January 31st, 2004, 12:01 PM
90hpmercuryproblem 90hpmercuryproblem is offline
its a 3 cylinder.
  #4
Old February 1st, 2004, 06:15 PM
Mercury140-I6 Mercury140-I6 is offline
A friend of mine had a Bayliner Reflex with a 90hp jet that did the same thing. It turned out to be one of the Power Packs, or stitches. Hope this helps.Craig
  #5
Old February 2nd, 2004, 09:15 PM
When you say powerpacks, are you referring to the powerhead?? What do you mean by reference to stitches??
  #6
Old February 2nd, 2004, 09:46 PM
Power packs might be the wrong term. Stator and Trigger are the terms I was thinking about. Have them checked.Hope this helps.Craig
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Twin sws 250 87' hard start after warmed up? Bob Finch Yamaha & Suzuki Outboards 6 November 17th, 2005 01:34 PM
64 75 hp Evinrude, No start after warmed up Evinrude Boater Johnson & Evinrude Outboards 4 July 14th, 2004 10:08 AM
Hard to start when warmed up Dead Eye Mercury & Mariner Outboards 8 June 19th, 2004 05:39 PM
warmed up engine will not re-start brown bomb Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 6th, 2003 06:44 PM
'86 170/470 slow crank/no start after warmed up... Jersey13 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 12 July 18th, 2003 02:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
