I have a 1998 Mercury 225 EFI. Just recently this outboard began to "lose power". Motor will start fine and seems to idle correctly. But, when trying to accelerate out of the hole, the motor will not climb above 2000-2100 RPMs. I have checked the compression on each cylinder and get readings of approx. 100 pounds per cylinder. When motor is idling, I have fire on every cylinder. I have tried checking the bulb when motor refuses to gain RPMs and bulb is tight. I have also tried to choke the motor to see if this will "help" with the problem, it does not. I am lost. Has anyone out there ever experienced this problem before. I would be very grateful for any help that you could provide.
