  #1
Old January 18th, 2004, 04:31 AM
surfbass surfbass is offline
Default Mercury starter
I have a 2000 mercuty 90hp outboard. For the last month it has turned over slow on the initial cold start then done fine the rest of the day (possible starter drag ?). Yesterday it started then died then would not turn over again. When this happened the tilt trim also stopped working.Also with the bilge pump running I could turn the key or press the trim button and it turned the bilge off for about five seconds then it would slowly start back up. My uneducated guess is bad starter but I would appreciate advice from some of you with more knowledge. Ya'll have a great board here and any advice is much appreciated.
  #2
Old January 18th, 2004, 06:41 AM
Clams Canino Clams Canino is offline
Default Re: Mercury starter
Put a charger on the battery. Sounds to me like it's failing.-W
  #3
Old January 18th, 2004, 09:40 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
And snug-up those wing nuts with a pliers.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #4
Old January 18th, 2004, 10:48 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Have battery load tested at any auto parts house. How old is it? Could have a bad cell..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #5
Old January 18th, 2004, 11:31 AM
Thanks for the responses. The tilt trim is wired in with the two main motor wires that go to the battery. With the wires hooked to the battery the trim doesnt work. To get the motor tilted up I unhooked the wires for the tilt at a joint and used jumper cables to hook directly to the wires and raised the motor using the same battery. If the battery raised the motor with the jumper cables then it has enough juice. OR am I missing something? Also after reading some old posts I shorted between the positive post on the cylinoid and the small positive stud. The starter did not turn.All I got was sparking.
  #6
Old January 18th, 2004, 12:03 PM
Hooty Hooty is offline
Check the voltage at the pos. (+) post on the starter when you jumper the starter solenoid. If you've got a full 12vdc, the starter is busted. c/6Hooty
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
-04 Mercury 150 Starter Problems dieterly Mercury & Mariner Outboards 4 December 14th, 2005 01:50 PM
Mercury Starter - OE or Aftermarket spidc60 Mercury & Mariner Outboards 3 June 2nd, 2005 01:33 PM
Mercury 200 Starter crawco Mercury & Mariner Outboards 3 May 6th, 2003 06:40 AM
Mercury starter Vahevala Mercury & Mariner Outboards 1 March 24th, 2003 01:36 PM
Starter for 78 mercury 20 hp TbaileyJr Mercury & Mariner Outboards 1 December 30th, 2002 12:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
