I own a 1999 Merc 225 EFI, I am looking for an aftermarket electric fuel pump. The OEM part number for the kit is 809088T, I seem to be having alot of trouble finding an aftermarket pump and the OEM price is just out of this world. Being an ASE Mastertec it really is starting to make me sick to have to pay the price for an OEM fuel pump. If someone has run into this problem before your help would be greatly apriciated.
Think you might have hit the wrong selection, you will get better info in the Merc site, I'm sure one of the moderators will move it for you. Good Luck.
There is two electric fuel pumps on that engine. There is a low pressure fuel pump on the out side of the VST. The high pressure is on the inside of the VST. First you need to know which fuel pump you need. The low pressure fuel pump is made by carter. The low pressure fuel pump can be bought aftermarket. If the engine has sat a long time 6 months or more you will need to replace both fuel pumps and clean the vst.
I looked at an old high pressure electric fuel pump. The name on it is Wilburo. I have not found a source for this pump (aftermarket). I know carter makes the low pressure electric fuel pump. There is two of the low pressure pumps 1. is 25 gal/hr. 2. is 45gal./hr. Both are low pressure.
