I took my 22 aquasport out today on its 'maiden voyage' under my ownership, and ran into some 'wierdness' with the control box and gauges. Any suggestions are helpful.<br /><br />The engine (1985 merc 200HP blackmax) ran like an absolute top... However while running at about 3500 rpm for about 10 minutes, an alarm went off in the control box. I immediately throttled back to make sure it wasnt an overheat alarm - engine was still peeing and the block wasnt hot to the touch... The engine has a new stainless steel water pump last fall and a new thermostat ... So it probably WASNT overheating, as tyhe engine was running fine, the telltale water wasnt hot, just warm to the touch, and the block behind the flywheel wasnt hot.<br /><br />After I throttled back, I lost all my gauges. The engine continued to run just fine. I tried to trim the motor up some, and i lost my power trim as well. I figured I blew a fuse, so I went on my merry way. When i got back to the launch to put the boat back on the trailer, i tied off to the dock and started looking for fuses. I subsequently did the following:<br /><br />Looked for fuses, disconnected the wiring connector to the control box, put back together, changed the battery switch to battery 1 (was running on 2). I then tried the trim, and it was back, along with all the gauges. <br /><br />I suspect it is a faulty alarm as the engine wasnt overheating - but why would this kill all my gauges - no tach, trim gauge, fuel, or power trim buttons. <br /><br />Please help!!! Could this be a faulty control box? I don't wanna throw parts at it!
