  #1
Old October 21st, 2003, 09:48 AM
BJM BJM is offline
Default 92 115 Mariner - How does the 2+2 cylinder operation work
My 92 115 Mariner runs on 2 cylinders below 2000 RPM. The top 2 kick in only above 2000 RPM. How is this accomplished? Can it be bypassed?My other question is this, if the carbs are halting fuel delivery to those cylinders, how are they lubricated while not firing?
  #2
Old October 21st, 2003, 11:35 AM
Kenny Bush Kenny Bush is offline
Default Re: 92 115 Mariner - How does the 2+2 cylinder operation work
The control module kills the spark to those cylinders. Fuel and oil are still going through.
  #3
Old October 21st, 2003, 01:39 PM
MurdockJr MurdockJr is offline
BJM the bottom two carbs have no idle circuit. Bottom two carbs kick in at about 2000rpm with the help of an accelerator pump. The only way to make it idle on all four would be to buy two top carbs with the idle circuit and replace the other two. The spark is not killed on the bottom two cylinders, it's all in the carbs.
  #4
Old October 21st, 2003, 01:50 PM
I was told that several models have the ECU kill a cylinder or two to reduce RPMs to an idle. My V6s all have idle screws on the carbs, and they are preset(plastic caps slid over them). I have not owned a 4 cylinder 115 (yet), so I cant verify carb settup..... Come on Merc Techs....chime in here with the song/verse.......
  #5
Old October 21st, 2003, 04:22 PM
Sorry Bushcat I have the 115 with the 2+2 and the ecu has nothing to do with it. I'm not here to argue but if you don't know don't reply.
  #6
Old October 21st, 2003, 05:19 PM
DJ DJ is offline
Ditto, MurdockJr.
  #7
Old October 21st, 2003, 05:42 PM
clanton clanton is offline
All in the carbs on the 4 cylinder merc. Manual not real clear how the 2 lower cylinders get oil. The oil is mixed with the fuel before it reaches the carbs, so should be some fuel flow, unless Merc thinks it does not need oil at idle.
  #8
Old October 21st, 2003, 06:32 PM
The Marine Doctor The Marine Doctor is offline
The bottom 2 carbs still supply fuel, but not enough to fire.TMD
  #9
Old October 22nd, 2003, 09:36 AM
BJM BJM is offline
I must admit I have forgotten which 2 cylinders turn off, top or bottom. However when I adjusted the idle mixture 2 years ago (the dealer did a poor job) there were only two carbs to be adjusted. When the engine is running on muffs you can hear sharp reports as you near 2000 RPM. I get the impression its fuel building up in the exhaust and igniting once in a while. I guess it could be a trickle from the two cut cylinders building up. The reports get closer together as you near 2000. I don't like running the engine fast on the muffs so I don't really know how it sounds on all four out of the water.On my 19' Regal, it would be nice if the transition occured at 1500 RPM instead. The fastest non-planing speed is affected by the engine trying to start and stop the other cylinders, its quite annoying with all the jerking.I was really wondering if excessive idling would run it dry of oil.
  #10
Old October 22nd, 2003, 05:48 PM
werdna werdna is offline
Location: Rossmoyne, Perth, Western Australia, Australia
How big a deal is it to disable the 2+2? It drives us nuts, as most of the speed limits on local waters in Aus are 8knts, but the 2+2 kicks in at about 6knts and pushes the old tub up to 10knts...CheersAndrew
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tilt & Trim won't work , Why ? 1993 Mariner cootersplace Mercury & Mariner Outboards 1 August 6th, 2007 12:54 PM
Will Change mid & lower of 96 Merc 175 to 93 Mariner work? random1 Mercury & Mariner Outboards 0 January 29th, 2007 07:39 PM
a series mariner wiring 4 consul operation ambo matt Mercury & Mariner Outboards 0 December 6th, 2004 11:00 PM
1981 40hp Mariner Erratic Operation 63seasprite Mercury & Mariner Outboards 7 August 19th, 2003 05:55 AM
will this starter work- 3 to 4 cylinder? 17winn Johnson & Evinrude Outboards 0 July 19th, 2002 01:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
